Quirk 1.
A user posted some text and a code block. I highlighted both and the Quote/Reply buttons appeared but you could not click them. I highlighted because this was a very long post and I only wanted to talk about the code block and text above it. The reason I call this a quirk is, if you click Reply on the actual post, it does quote the text and code blocks. So you have to edit away the rest. Highlight should do this for you.
Quirk 2.
If I highlight a passage that is all bold, and...
Quirk 2.
