Solution MissPariya May 30, 2023 Diann said: Hi forom Change the color of links in posts? Click to expand... Add-ons - [OzzModz] Post Link Color - History xnforo.ir TRY Less: .message-userContent .link { color: yellow; }
T trupush Registered May 29, 2023 #2 Diann said: Hi forom Change the color of links in posts? Click to expand... using this, but i had not find null lasted version, old version not support xenforo 2.2+ [XTR] External Links Redirect Warning lasted version is 1.0.4, if you buy this add on, please share with me, thank you Upvote 1 Downvote
MissPariya Registered May 30, 2023 #3 Diann said: Hi forom Change the color of links in posts? Click to expand... Add-ons - [OzzModz] Post Link Color - History xnforo.ir TRY Less: .message-userContent .link { color: yellow; } Upvote 1 Downvote Solution
