alodda
Engage Box 4.2.0 is a new version of the best Joomla extension to create any popup on site pages, and this can significantly increase the number of subscribers. This pack (plugin and widget) allows you to easily implement all kinds of blocks (mods, slides, sliders, sidebars). From the functionality, it is possible to notice support for Exit-Intent technology (detection of the behavior and exit of a block when exiting), a segmented mailing list, loading of Joomla modules in blocks and more than 60 effects.
Features:
- Template Library
Out of the box, responsive and highly customizable pop-up templates so you can get started in just minutes - Various types of pop-up windows
Pop-up windows. Floating rods. Full screen overlays. Slides, 2-step preferences, powerful conversion tools at your fingertips. - Precise targeting
Every visitor is different. Why does he treat everyone the same? Use precise targeting to show relevant messages. - Smart triggers
Detect visitor behavior and use smart triggers to show the right pop-up to the right person at the right time. - Highly customizable
Total control of the look. Colors, size, background, border, fills, overlay, and much more. - Compatible with mobile devices
The web is no longer just a desktop. That’s why EngageBox is 100% mobile optimized and responsive. - 60+ animation effects
Play the role of a director with over 60 stunning animation effects. - Position anywhere
Set your pop-up window to appear from any corner of your website. - Arise
The most effective and popular way to grow your email list. - Fullscreen
Create a full screen box with a call to action that cannot be ignored. - Scroll Scroll Box
High converting alternative to floating corner pop-up. - Floating bar
Increase conversion with header footer or sticky bar. - Sidebar box
Turn every page on your website into a lead generation opportunity. - but
Let the visitor choose what action they want to do next. - Welcome mat
A screen fill box that slides and pushes the content down. - Blocked content
Convert a page to premium content and watch your email list grow. - Purpose of the output
Convert abandoned visitors into subscribers and customers. - In displacement
Automatically displays a popup window when the user scrolls% of the page. - Clicking
Displays a pop-up window when the user clicks a button, link, or title. - Scheduled screen control
Activate a popup after browsing a page for X seconds. - When the page loads
Automatically displays a pop-up window when a visitor opens your site. - Hovering over
Displays a pop-up window when the user reaches certain parts of the page. - Trigger inactive
Target inactive visitors and convert them to subscribers. - AdBlock detection
Identify visitors using ad blocker software.
Demo:
The #1 Joomla Popup Builder Extension - EngageBox
Engage Box 4.2.0 - Download - Server Xnforo
