Gravitizer - Gravity Forms Material UI Styler
WP Plugins Gravitizer - Gravity Forms Material UI Styler 1.0.7
Gravitizer - Gravity Forms Material UI Styler - Download Nulled CodeCanyon 26570055
Gravitizer lets you make your traditional looking Gravity Forms into Material UI design in single click.
You can customize each and every settings of your field using the live visual styler.
Install
  1. Extract the zip file you get from Codecanyon
  2. You will find a file inside main folder named “gravitizer.zip”.
  3. Upload the gravitizer.zip from your dashboard.Finally...
