Gravity Flow WordPress Plugin
WP Plugins Gravity Flow WordPress Plugin 2.7.0
Gravity Flow WordPress Plugin - Download Free Gravity Flow WordPress Plugin Nulled
Modify forms before approval
Implement review loops allowing users to edit their values before re-submitting for approval. Use workflow conditional logic to branch the process or skip steps.
Rapid Implementation
Simple and easy to use
Configure as many Workflow Steps as you need. Drag and drop them into the right order, activate/deactivate them and add new ones as your process...
XenForo updated Gravity Flow WordPress Plugin with a new update entry:
Gravity Flow v2.7.0 Nulled
v2.7
- Added support for Gravity Forms 2.5-beta-3.
- Added filter gravityflow_entry_url_status_table to allow the url in status page to be customized.
- Added filter gravityflow_sort_columns_status_table to allow custom columns defined in gravityflow_field_value_status_table to be sorted
- Added filter gravityflow_sort_criteria_status to allow initial sort order on status page load to be defined.
- Added a setting to enable the Workflow Inbox count in the WordPress admin...
