class="fullview">element.style {
display: table;
width: 100%;
overflow: hidden;
height: auto;
Is there a shoutbox i can install
xnforo.ir
xnforo.ir
Your problem is with the style patternBut I did a fresh forum install.
I really do appreciate the quick support. This is my first time using XenForo Forums, And I'm not fimilure with how the widgets work. I have just installed the AndyB Chat. But I'm not sure how to put it on the fourms home page i put an example where I would like it.![]()
Add-ons - Shoutbox by Siropu
This is an easy-to-use easy-to-setup Shoutbox widget that you can add in any of the available widget positions on your board. Main features: Active user list Private staff room Shouts archive Enable "real-time" mode for improved performance Top...xnforo.ir
Add-ons - Chat - History
xnforo.ir
