R Russhvith Registered Dec 10, 2022 Thread starter #1 I see no options to set the cookies mode to Advanced. I searched the options tab under setup tab but no results were found. I upgraded from 2.2.11 to 2.2.12 but yet cant find it. P.S help
B Bryant Registered Dec 11, 2022 #2 Search for this in the management panel cookieConsent Then On the option Advanced Activate, Of course, it is still a beta version Upvote 0 Downvote
R Russhvith Registered Dec 11, 2022 Thread starter #3 I cannot find where is cookieConsent in management panel, can you help me with some screenshots? Upvote 0 Downvote
W WonderGirl Registered Dec 12, 2022 #4 Russhvith said: I cannot find where is cookieConsent in management panel, can you help me with some screenshots? Click to expand... You must search at the top of the panel Upvote 0 Downvote
R Russhvith Registered Dec 13, 2022 Thread starter #5 Ok i found it, just to make it easier, its Setup Tab -> Basic Options -> Cookie consent Upvote 0 Downvote
