Support How can i activate an SEO without Using Addon?
ngbaze
I need bits of help, how can I activate an SEO inside my xenforo without using any SEO addon, also with fast indexing like this forum Please? :cry:
its addon or script code ?
It's no addon or script code. It's the in-built feature of Xenforo.
Go to Xenforo Admin Panel > Content > Tags. Create 'Tags' as suitable for your threads. Then go to Forums > Nodes. Click on a 'Forum'. Go down. Click on 'Advanced Options'. Again go down and you will see an option 'Minimum required tags'. Set the number, generally it's 1 but you can put your own numbers and save. You should remember that you can set this option in 'Forums' only. You will not have this option in 'Categories'. Now this is the way of setting tags.
After doing all the above steps. Go to Setup > Options > Content Tagging and check 'Enable Content Tagging'. Now, after creating a thread, you will see an icon like the red marked portion in the picture below:
Click on that icon and you will see the Add / Edit Tag window. I think you can do the rest.
