Hi,
I'm using $form->basicEntitySave to save inputs from a form into my database which all works well, the only problem is that it allows duplicates which I don't want, so I'm probably missing something obvious but how do you check if the record exists before saving? Is there a build in function for that?
Thanks
Thanks
