Support How to edit url title on search engine
Bejay4sure
I want my site to be on a standard title on google search engine without (.com)
pls check the screenshot below
Brother use feature of admin.php?options/groups/seo/ go here and and enable
Convert URLs to page titles
and write {title}
in the box
wikislo
To change the text that shows up, you need to change your SEO title and description. To change this, click on your page's settings, go to SEO and then fill them in (attached).
Your SEO title should be 50-60 characters, and your SEO description should be 150-160 characters.
As for the helpful links that pop up, this is a bit more tricky. Putting the pages you want in the header of your website can help, as well as adding more internal links to the pages you want to show.
Overall, by having good on-page SEO and a solid page structure, you can impact what shows, but Google has a mind of its own!
Bejay4sure
i would love to understand this better sir.
