Hi,
I'm trying to add a search forum widget to my template by using the xf:widget syntax. My goal is to save the settings for the Widget in custom thread fields. But I think I need some help. Until now I tried:
The value 123 would be dynamic and would be replaced with a variable from custom thread fields. I can't us a manually created...
<xf:widget class="XF\Widget\SearchForum" node_id="123" />
<xf:widget class="XF\Widget\SearchForum" params="{{ {'node_id': '123'} }}" />
