regiontokyo
I tried writing some simple CSS into extra.less, but nothing changed, are there any docs that have all the classes?
Ask ChatGPT to help you. Make sure you specify the exact version of Xenforo you are using.I tried writing some simple CSS into extra.less, but nothing changed, are there any docs that have all the classes?
In the Template file, you specify the class value, and then enter in the extra.CSS file, its influence will take precedence.I tried writing some simple CSS into extra.less, but nothing changed, are there any docs that have all the classes?
