I tried to import from SMF 2.1.2, but always run into open_basedir errors.
Originally I installed XF into a different "webspace" in Plesk, than where SMF is. So I thought that might be the reason. But then I reinstalled it under the same webspace and the errors were identical. Now it is back in the other webspace.
I thought I'd give up on the import, but after reading that SMF 2.1 should work, I want to try to solve the open_basedir issue.
Any ideas?
Any ideas?
