Haim
Haim submitted a new resource:
(JD)Recycle Bin for Forum - (JD)Recycle Bin for Forum
This plugin allows you to enable the forum basket.
In the plugin settings, enable the desired forum example: BASKET (you will need to create a separate forum to select a basket for this forum)
When you delete content, your content will automatically be moved to the forum trash, updated to the latest version of IPS
