Lock forum nodes for specific user groups
Add-ons Lock forum nodes for specific user groups 1.0.0
XenBot
Supervisor
  • Staff
XenBot submitted a new resource:
Lock forum nodes for specific user groups - specific user groups
This is a small add-on and can be configured easily. You can lock up to 3 forum nodes.
The picture says it all ;)You can completely customize the messages displayed. Check out the AdminCP screenshot to see how the options work.
Install
Unzip and upload the "js" folder to the root of your Xenforo installation. Then go to "List Add-ons" -> "+Install Add-on", select the .xml file and import.
Configuration Go to
"Options" -> "Locked...
