sherkumbher
sherkumbher submitted a new resource:
MaterialX Flutter - Flutter Material Design UI Components - MaterialX Flutter - Flutter Material Design UI Components
This UI template is ready to use and support your flutter projects, you can pick some part you like and implement it into your code. All folder, file name, class name variable and function method is well organized and well named make this template easy to reuse and customize.
