[Andrew] Moderator Panel
Add-ons [Andrew] Moderator Panel 1.9.4
Moderator Panel - Expands Xenforo's existing moderator options into a more power moderator panel
[Andrew] Moderator Panel provides moderators enhanced visibility into user behavior and additional moderator features. The thought is that by providing better visibility to warnings, reports, thread bans, and ignores, moderators will be able to identify problem users faster and will rely less in impulse when making decisions on users. All features are permission controlled and can be enabled or disabled.
  • #3
XenForo updated Moderator Panel with a new update entry:
Version 1.4.2
  • FIXED: Most reported users will be hidden when send report to form is enabled
  • FIXED: Logs menu header would only display if certain logs were enabled
  • FIXED: User data menu header would only display if certain features were enabled
  • ADDED: Spam trigger log
  • ADDED: View spam trigger log permission
    add on moderator panel add ons [andrew] moderator panel download [andrew] moderator panel 1.7.0 download [andrew] moderator panel 1.7.2 download [andrew] moderator panel 1.7.4 download [andrew] moderator panel 1.7.5 moderator panel 1.5.0 nulled moderator panel xenforo moderator panel xenforo [andrew] moderator panel xenforo [andrew] moderator panel 1.7.5 xnforo.ir [andrew] moderator panel [andrew] moderator panel 1.5.0 [andrew] moderator panel 1.5.1 [andrew] moderator panel 1.5.2 [andrew] moderator panel 1.5.3 [andrew] moderator panel 1.6.1 [andrew] moderator panel 1.6.2 [andrew] moderator panel 1.7.0 [andrew] moderator panel 1.7.2 [andrew] moderator panel 1.7.4 [andrew] moderator panel 1.7.5 [andrew] moderator panel 1.7.6 [andrew] moderator panel 1.7.7 [andrew] moderator panel 1.7.8 [andrew] moderator panel 1.7.9 [andrew] moderator panel 1.9.1 [andrew] moderator panel 1.9.2 [andrew] moderator panel 1.9.4 بهینه سازی پنل مدیریت
