I itsmearff Registered Jun 4, 2025 Thread starter #1 I am using MaterialXen by DohTheme theme on my website. but I see the text on the footer that still shows that this theme is made by DohTheme, how can I remove the text?
Solution Narges Jun 8, 2025 itsmearff said: how can I remove the text? Click to expand... XenForo - Remove copyright XenForo 2.2
ZExA Registered Jun 6, 2025 #2 Hi, Try to go in you admin panel and in Appearences-->Templates and select your theme you want to remove the copyright . Then find PAGE_CONTAINER And when you are inside you will see a line like: {{ phrase('extra_copyright') }} <br /> <a href="XenTR | XenForo Add-ons and Styles" class="u-concealed" dir="ltr" target="_blank">Xenforo Theme<span class="copyright"> © by ©XenTR</span></a> I guess you can try to remove it. Upvote 0 Downvote
Narges Registered Jun 8, 2025 #3 itsmearff said: how can I remove the text? Click to expand... XenForo - Remove copyright XenForo 2.2 Upvote 0 Downvote Solution
ZExA Registered Jun 9, 2025 #4 Narges said: XenForo - Remove copyright XenForo 2.2 Click to expand... Thats work too Upvote 0 Downvote
