I noticed avatars were sometimes being saved twice when uploading (annoying when you are using a 3rd party API for storing them). It's saved once when you upload it, and then again when you hit "Okay" on the Avatar window.
Did a little digging, and it appears to think there's an avatar crop adjustment even when there is none. If you upload the attached avatar, the
xf_user_profile.avatar_crop_y column is set to 16. When you hit "Okay" to close the dialog, that value changes...Read more
