Oxygen Builder
WP Plugins Oxygen Builder 3.7.1 Nulled
Oxygen Builder - Powerful visual site builder for WordPress
More Than Just Design
In addition to the best design capabilities on the market for every part of a page, Oxygen's templating and dynamic data functionality brings the same power to headers, footers, archives, blog posts, custom post types, plugin pages, and everywhere else.
If you can do it with WordPress, you can design it with Oxygen
XenForo updated Oxygen Builder with a new update entry:
Oxygen Builder v3.7 Nulled
  • New: Added native CSS grid controls for Sections, Divs, Easy Posts, Repeaters, and Galleries.
  • New: Added support for Composite Elements library.
  • Fix: Attributes now work properly when assigned while an element’s class is the active selector
  • Fix: Deleting styles no longer deletes non-CSS options like Attributes.
  • Fix: Fixed issue where re-signing shortcodes that contained Oxygen WooCommerce shortcodes while the Oxygen WooCommerce plugin wasn’t active resulted in broken...
  • #3
Oxygen Builder v3.7.1 Nulled
Oxygen v3.7.1 Changelog
  • Fix: Corrected shortcode warning that appeared when using some third-party shortcodes in a Shortcode element and prevented shortcode signing from running on pages with those shortcodes present.
  • Fix: Grid controls are now hidden from users with Edit Only access.
  • Fix: Composite Elements license field is hidden if your Agency license has already enabled Composite Elements
