[OzzModz] Edit Silently And Clear Edit History Checked - Auto check the edit silently and clear last edit history checkboxes
This simple addon will automatically check the edit silently and clear last edit history checkboxes.
There are three settings for the addon.
Note, the clear...
- Edit silently checked. You can set the edit silently box to be automatically checked.
- Clear last edit information checked. You can set the clear edit history box to be automatically checked.
- Allowed user groups. You can select which usergroups will see the checkboxes automatically checked.
