[RSS Feed/News] PHP post_max_size set 0 disables attachements?
This is more of a question about the internal processing.
In the PHP documentation, it states you can set post_max_size to 0, indicating you would like to disable the limit checking of the post size. (NOTE: Do not do this in your production server, bad things may result). Some test installations will leave this set as a default.
If you look in the XenForo admin screens under setup > options > Attachments the recommendation under the setting box reflects the setting of the...
