XenForo Protect your content easy way (Do Not Copy)
alodda
If you don't want original content from your site copied and used in other forums and sites, read on.
Even though there are plugins available, I will share with you a way to protect your content with a very simple code structure and no plugins.
Open ( your style ) PAGE_CONTAINER
! Add this codes mentioned at the bottom of our template !
JavaScript:
<script>
$(document).bind('copy', function(e){
alert('Oops!.. Copying Content From Our Site Is Forbidden !!!'); // Make alert for your visitors.
return false;
</script>
Result :
Another Way
The safe way because java sometimes is crappy depending on the browser
JavaScript:
<script>
jQuery(document).bind("contextmenu", function(e) {
e.preventDefault()
    return false;
});</script>
As usual if you want to allow admin to copy :)
add this code
HTML:
<xf:if is="$xf.visitor.isMemberOf(3)">
    <xf:else />
<script>
    e.preventDefault()
    return false;
});</script>    </xf:if>
enjoy
JavaScript:
<script>
return false;
</script>
Result :
Another Way
JavaScript:
<script>
e.preventDefault()
    return false;
});</script>
add this code
HTML:
    <xf:else />
<script>
    e.preventDefault()
    return false;
enjoy
Right click is not working, that's good. But ctrl+c / ctrl+p is working. Can it also be blocked?
This type can also be used
  • Add to the end of the template
  • page_container
JavaScript:
<script>
      return false;
</script>
<script>
      alert('Oops . Copying Content From Our Site Is Forbidden');
      return false;
</script>
alodda
Another way for disable, right click & cut copy paste
Try this
JavaScript:
<script type="text/javascript">
$(document).ready(function () {
    //Disable mouse right click
    $("body").on("contextmenu",function(e){
        return false;
    //Disable cut copy paste
    $('body').bind('cut copy paste', function (e) {
        e.preventDefault();
</script>
