[RSS Feed/News] signal SIGSEGV, Segmentation fault?
Seen this a few times in the logs recently. I've managed to create a core dump file and view it with gdb, the problem is I still don't understand the output.
Anyone know whats going on?
php-fpm8.0
warning: Can't open file /dev/zero (deleted) during file-backed mapping note processing
[New LWP 61657]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
Core was generated by `php-fpm: pool www...
