ThanosCrax
Some things people might like if changed [All upto staff team] These are just some suggestions
1: Change the default theme, I like the Dark one which gives a real foxy look xD
2: Add [tl] Post Reply add-on bcs I like the way messages are sorted one above the other so its not hard to reply the other guy rather than a whole new shit going down and down and down.....looks creepy and hard to understand.[I use it on my own forum and works nice and sexy]
3: I can see Live Forum statistics add-on is being used however remove the new user bar its so much useless and bad looking
also u removed the most useful tab from Threads that are:
- New Threads
This one helps keep the track of newly posted resources and I often like bcs its small and easier to use anytime
Rest I love this forum and its great Staff team that helps a lot
Thanks <3
Post Reply
Allow replies in thread on more levels. This add-on uses a post system so you can have all permissions, features in the system and when uninstalling add-on your data is still there. Enable replies on specific forums You can easily turn on or off...
xenforo.com
- New Threads
Thanks <3
