[TH] Nodes for grid, custom styling, and custom icons
Add-ons [TH] Nodes for grid, custom styling, and custom icons 1.1.2 Patch Level 1
[TH] Nodes for grid, custom styling, and custom icons - Easily style your nodes and arrange them into a grid
Nodes
Add dimension, quality, and allure to the display of your forum list, and stand out from your competition. [TH] Nodes can help you create a visually engaging forum and improve user experience with visual indicators by allowing you to style nodes, icons, and more.
Administrator Features
  • Modify the grid, sizing, background colors, icons, and more for each node with...
XenForo updated [TH] Nodes for grid, custom styling, and custom icons with a new update entry:
[TH] Nodes for grid, custom 1.1.0 Patch Level 7
Changes:
  • Fixed an issue that caused "Revert Style" button to not work when using it
  • Fixed an issue that caused duplicate icons to show on the titlebar
  • Fixed an issue that caused sub-forum icons on the drop-down to not sync with custom set read/unread icons
  • Fixed an issue that caused titlebars to center align when node icons are added
  • Fixed an issue that caused custom category, page, and link icons from being used
  • Fixed an issue that caused a notification to...
  • #3
[TH] Nodes for grid, custom styling, and custom icons 1.1.1
Version 1.1.1 released!
Changes:
  • Fixed an issue that caused search forums to lose their icons on the sub-forum drop-down
  • Fixed an issue that caused search forums to break when [TH] Nodes is enabled
  • Fixed an issue with the node layout separator which seemed to break gutter settings for the node grid
  • This update breaks backwards-compatibility with XenForo 2.1 and lower.
mRX
hi
i tried this with Exclusive Dark 2.2.6
it works fine when i log to the forum as a member but Guest/Visitor menu is not working
what i should do is it a template error or theme not compatible with the plugin :(
thanks!
    add ons [th] nodes for grid custom styling and custom icons [th] nodes for grid [th] nodes for grid custom styling and custom icons [th] nodes for grid custom styling and custom icons 1.1.1 patch level 1
