Toolkit for Elementor
WP Plugins Toolkit for Elementor 1.3.13
Toolkit for Elementor - Enhance Elementor with time-saving
Speed up media-heavy pages with Booster’s set of performance tweaks specifically dialed in for the WordPress framework.
  • Run GTMetrix Scans Right From Your Dashboard
  • LazyLoad Images & Media
  • Minify & Combine JS, CSS
  • Dequeue Common WP Bloat
  • Dequeue Unused Elementor, WP, and Dashboard Widgets
Go Themeless With Toolkit For Elementor
As of Elementor v2.9, the new...
XenForo updated Toolkit for Elementor with a new update entry:
v1.3– 2020-02-08
  • [NEW!] Dashing > Login Page design options
  • [NEW!] Dashing > Ability to define Login Page URL
  • [NEW!] Booster > Database Optimization
  • [NEW!] Booster > Script Ninja > Ability to dequeue CSS & JS Scripts
  • [NEW!] Booster > Misc Tweaks >Ability to Backup & Download htaccess files
  • [NEW!] Syncer > 404 and Search Results template types added
  • [PERFORMANCE] Improved Defer JS compatibility...
  • #3
v1.3.2– 2020-02-18
  • [NEW!] Syncer > Ability to search for templates
  • [API UPDATE] Syncer Keys updated to use site url instead of name
  • [BUG FIX] When certain Elementor Experimental features are enabled, some users see double settings tabs
  • [COMPATIBILITY] Tested & Updated Elementor Pro Compatibility Tag to 3.1
v1.3.1– 2020-02-16
  • [NEW!] Syncer > support for Landing Pages (Elementor Experiments)...
  • #4
v1.3.3– 2020-02-23
  • [UX IMPROVEMENT] Syncer > results auto-populate while searching for faster user experience
  • [DEPRECATED] Removed jquery.sonar.min.js (1.38kb) as it is no longer used as of v1.3
  • [BUG FIX] Code Manager > Google Tag Manager token error for some users if Defer JS enabled
  • [COMPATIBILITY] Tested & Updated Elementor Pro Compatibility Tag to 3.1.1
  • #5
    toolkit for elementor v1.3.13
