Unlimited Elements for Elementor Pro
WP Plugins Unlimited Elements for Elementor Pro 1.5.81
CodeCanyon
  • Moderator
CodeCanyon submitted a new resource:
Unlimited Elements for Elementor Pro - Plugin Nulled Free Premium
Unlimited Elements for Elementor Pro NULLED is The Biggest & Best Elements Library for Elementor. A library of unique Elementor Widgets that add more functionality and flexibility to your favorite page builder.
Power up your page builder using our easy-to-use & creative widget library. Make your next web design project look prettier than ever before with Unlimited Elements.
There are many actions you can do with each widget...
CodeCanyon
  • Moderator
CodeCanyon updated Unlimited Elements for Elementor Pro with a new update entry:
Unlimited Elements for Elementor Pro (Premium) v1.5.60 NULLED
-bug fix: fixed link field settings for multisoure
-bug fix: fixed some bugs with regular price in woocommerce widgets
-bug fix: filters js file loaded in editor as well
-bug fix: fixed some small php bug regarding "pathBase"
-change: updated unite gallery version
-change: disabled autoload in update_option for the catalog variable
-feature: added functionality to get cart number of products
-bug fix: fixed conditions in multiple select control
CodeCanyon
  • Moderator
  • #3
Elementor PRO v3.13.0 NULLED
  • Tweak: Provided an option to assign excerpt automatically from post content in Post Excerpt dynamic tag (#20256, #21715)
  • Tweak: Added Display Conditions functionality in Editor Top bar (#21675, #22050)
  • Tweak: Removed elementor_page_id from request URLs in the WC AJAX calls (#18675)
  • Tweak: Added icons to menu items in Mega Menu widget (#21602)
  • Tweak: Added keyboard accessibility to Toggle Button in WordPress Menu widget (#2348)
  • Tweak: Added ‘Active item state’ to...
CodeCanyon
  • Moderator
  • #4
