If you try and install an addon on the CLI but haven't installed the composer packages first, you get an error
If you have an addon installed and try and build a release with listeners enabled and haven't installed the packages, you get an error...
The site is currently being upgraded. Please check back later. repeated several times. As it wasn't obvious this was due to missing composer packages I disabled listeners and installed the addon and then built a release.If you have an addon installed and try and build a release with listeners enabled and haven't installed the packages, you get an error...
