Request Woltlab Suite
scooterdud
VieCode Webdisk / Filebase 3.3.3​
The VieCode Filebase is a powerfull filebase for your community!
VieCode Filebase is the right extension if you want to present a large number of files in a concise format. In addition to the modern and dynamic interface, the usual extensive moderation and administration are of course still available.
Compatibility​
The VieCode Filebase can be operated in WSC 5.4 or higher. For older WSC installations there is a separate version. Existing customers can upgrade to the current version at a discounted price (~15€).
Features​
New Features (Version 3.3)​
Versions support​
In the VieCode filebase, files are often shared that have a version number. In the settings you can now optionally activate that entries now support version numbers.
Supported Versions
WoltLab Suite 5.4
WoltLab Suite 5.5
  • com.viecode.filebase.tar.gz.zip
    woltlab suite
