Support XF 2.2.8 p1 help please
clive
HI, So on localhost and XAMPP i get a message after install and update. So today I test a clean install xf 2.2.8 p1 on web hosting server and always seem to get following message.
Anyone else getting same install problem?
thanks
thanks
This is nothing. This means that your Xenforo installation is unable to check for upgrades and that means, you are safe. Because if your localhost Xenforo installation could check it, then Xenforo would know that you are using a nulled Xenforo. So, don't worry, be happy. As long your Xenforo is downloaded from here, you are safe.
clive
Many thanks for your replies @XenForo and @DarKMaSK - So does this mean XF 2.2.8 p1 can NOT be used on live web hosting? I have un-checked xenforo software to check for up-dates in ACP setting.
Maybe I need to buy license for XF but still do not want this reporting back.
Thanks guys
Thanks guys
I am using nulled Xenforo for my live forum for a pretty long time and I had no problem. Look, when your forum is small, there will be no problem at all. But, when your forum will start coming up towards 1st page in search engines, then ... I don't know... someone from somewhere may try to poke a pin in your butt and in my opinion, at that time you may need a license. It will be helpful. But till that time, you can use the nulled xenforo without any problem. Actually, in future, I will continue to use nulled Xenforo downloaded from here but will buy a license just in case.
And regarding reporting back, whatever you will download from here, will not be able to reporting back even if you don't uncheck the update check. That is the speciality of 'Nulling'.
