[XTR] Unlimited Prefix Styles
Add-ons [XTR] Unlimited Prefix Styles 1.0.2
[XTR] Unlimited Prefix Styles - Best way to create unlimited prefix style
This add-on allows you to create unlimited prefix styles and you may select them easily per each prefix.
XenForo 2.2.x Compatibility
  • Requires PHP 7.2+
  • Supports only XF 2.2.2+
Note: Please do not install the add-on, if you are using lower than XF 2.2.2.
XenForo updated [XTR] Unlimited Prefix Styles with a new update entry:
Changelog 1.0.1
This is a major update, we recommend uninstalling the old version and then re-install the new one.
Please review the resource images to follow the update changes.
Version string 1.0.10
  • Added new phrases.
  • Added new public templates.
  • Added resource manager prefix support.
  • Updated new style properties.
  • Changed the ACP option template.
  • Added ACP navigation route.
XenForo 2.2.x and PHP 8.1+ Compatibility
  • Confirm XF 2.2.12+ Support
  • PHP...
Tony_41
Good evening, after 4 prefixes creation the icon is not displayed anymore? Do you have a solution
    add ons [xtr] unlimited prefix styles css اختصاصی برای پیشوند ؟ downlad [xtr] unlimited prefix styles free [xtr] unlimited prefix styles nulled [xtr] unlimited prefix styles xenforo [xtr] unlimited prefix styles [xtr] unlimited prefix styles [xtr] unlimited prefix styles 1.0.0 [xtr] unlimited prefix styles 1.0.1 [xtr] unlimited prefix styles 1.0.2 پروفیکس
