سلام متاسفانه سایتم از دیشب اینجور شده و لود نمیشه
ارور لاگ هایی که ساخته بود:
دانلود
پیوست نمیشد مجبور شدم اپلود کنم
لطفا راهنمایی کنید
# Mod_security can interfere with uploading of content such as attachments. If you
# cannot attach files, remove the "#" from the lines below.
#<IfModule mod_security.c>
# SecFilterEngine Off
# SecFilterScanPOST Off
#</IfModule>
## Force SSL ##
RewriteCond %{HTTPS} !=on
RewriteRule ^ https://%{HTTP_HOST}%{REQUEST_URI} [L,R=301]
<IfModule mod_rewrite.c>
RewriteEngine On
# If you are having problems with the rewrite rules, remove the "#" from the
# line that begins "RewriteBase" below. You will also have to change the path
# of the rewrite to reflect the path to your XenForo installation.
#RewriteBase /ip.board
# This line may be needed to enable WebDAV editing with PHP as a CGI.
#RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
# IPS Rewrite Rules
RewriteCond %{REQUEST_URI} /(topic|forum|user)/ [OR]
RewriteCond %{QUERY_STRING} (^|&)show(topic|forum|user)= [OR]
RewriteCond %{QUERY_STRING} ^/(topic|forum|user)/ [OR]
RewriteCond %{PATH_INFO} ^/(topic|forum|user)/
RewriteRule ^.*$ ips2xf.php [NC,L]
RewriteCond %{REQUEST_FILENAME} -f [OR]
RewriteCond %{REQUEST_FILENAME} -l [OR]
RewriteCond %{REQUEST_FILENAME} -d
RewriteRule ^.*$ - [NC,L]
RewriteRule ^(data|js|styles|install) - [NC,L]
RewriteRule ^.*$ index.php [NC,L]
</IfModule>
ErrorDocument 401 default
ErrorDocument 403 default
ErrorDocument 404 default
ErrorDocument 405 default
ErrorDocument 406 default
ErrorDocument 500 default
ErrorDocument 501 default
ErrorDocument 503 default
RewriteEngine On
#RewriteBase /xenforo
# This line may be needed to workaround HTTP Basic auth issues when using PHP as a CGI.
RewriteRule ^(data/|js/|styles/|install/|favicon\.ico|crossdomain\.xml|robots\.txt) - [NC,L]
</IfModule>
کدهایه .htaccess بنده نسخه زنفورم 2.1 میباشدHTML:# Mod_security can interfere with uploading of content such as attachments. If you # cannot attach files, remove the "#" from the lines below. #<IfModule mod_security.c> # SecFilterEngine Off # SecFilterScanPOST Off #</IfModule> ## Force SSL ## RewriteCond %{HTTPS} !=on RewriteRule ^ https://%{HTTP_HOST}%{REQUEST_URI} [L,R=301] <IfModule mod_rewrite.c> RewriteEngine On # If you are having problems with the rewrite rules, remove the "#" from the # line that begins "RewriteBase" below. You will also have to change the path # of the rewrite to reflect the path to your XenForo installation. #RewriteBase /ip.board # This line may be needed to enable WebDAV editing with PHP as a CGI. #RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization}] # IPS Rewrite Rules RewriteCond %{REQUEST_URI} /(topic|forum|user)/ [OR] RewriteCond %{QUERY_STRING} (^|&)show(topic|forum|user)= [OR] RewriteCond %{QUERY_STRING} ^/(topic|forum|user)/ [OR] RewriteCond %{PATH_INFO} ^/(topic|forum|user)/ RewriteRule ^.*$ ips2xf.php [NC,L] RewriteCond %{REQUEST_FILENAME} -f [OR] RewriteCond %{REQUEST_FILENAME} -l [OR] RewriteCond %{REQUEST_FILENAME} -d RewriteRule ^.*$ - [NC,L] RewriteRule ^(data|js|styles|install) - [NC,L] RewriteRule ^.*$ index.php [NC,L] </IfModule> ErrorDocument 401 default ErrorDocument 403 default ErrorDocument 404 default ErrorDocument 405 default ErrorDocument 406 default ErrorDocument 500 default ErrorDocument 501 default ErrorDocument 503 default <IfModule mod_rewrite.c> RewriteEngine On # If you are having problems with the rewrite rules, remove the "#" from the # line that begins "RewriteBase" below. You will also have to change the path # of the rewrite to reflect the path to your XenForo installation. #RewriteBase /xenforo # This line may be needed to workaround HTTP Basic auth issues when using PHP as a CGI. #RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization}] RewriteCond %{REQUEST_FILENAME} -f [OR] RewriteCond %{REQUEST_FILENAME} -l [OR] RewriteCond %{REQUEST_FILENAME} -d RewriteRule ^.*$ - [NC,L] RewriteRule ^(data/|js/|styles/|install/|favicon\.ico|crossdomain\.xml|robots\.txt) - [NC,L] RewriteRule ^.*$ index.php [NC,L] </IfModule>
#</IfModule>
RewriteEngine On
$config['enableListeners'] = false;
