Advanced Custom Widgets
IPS Suite Advanced Custom Widgets 1.0.7
Haim
Haim submitted a new resource:
Advanced Custom Widgets - Advanced Custom Widgets 1.0.7
Added two more settings to customize fixed widgets. Switch type. Now you can choose whether you want the switcher to save and remember the switch using browser cookies, for example if you open a fixed widget you need to switch to close even after refreshing the Switcher page. Now you can choose from two different switch styles.
Advanced Custom Widgets allows you to add additional custom TXT and HTML widgets to your site, you can add default and patched widgets. Each added widget is fully...
