AI Engine Pro: ChatGPT Chatbot
WP Plugins AI Engine Pro: ChatGPT Chatbot 1.9.3
CodeCanyon
  • Moderator
CodeCanyon submitted a new resource:
AI Engine Pro: ChatGPT Chatbot - Plugin Nulled Free Premium
Power your WordPress with AI! GPT Generate content, enhance it, improve your SEO, add a ChatGPT-like chatbot, etc.
Create a chatbot like ChatGPT (or any other), generate content, images, let you organize everything in templates, quickly suggest titles and excerpts, track your OpenAI usage stats, and much more! Then explore the AI Playground to try out a variety of AI tools like translation, correction, SEO, suggestion, WooCommerce...
CodeCanyon
  • Moderator
CodeCanyon updated AI Engine Pro: ChatGPT Chatbot with a new update entry:
AI Engine Pro v1.3.90 NULLED
= 1.3.90 (2023/03/30) =
* Add: Sync Posts with Embeddings (on Publish, on Update, and on Trash).
* Update: When missing orphan embeddings are found (a vector is in Pinecone, but not in WordPress), a specific orphan entry will be created. You can safely delete it. Best to keep everything clean.
* Update: Pinecone servers.
* Update: Internal API.
CodeCanyon
  • Moderator
  • #5
