Alert Improvements by Xon
Add-ons Alert Improvements by Xon 2.13.1
  • #6
XenForo updated Alert Improvements by Xon with a new update entry:
2.9.0 - Feature & bugfix update
  • Require php 7.2+
  • Require XenForo 2.2+, remove XF2.1 support
  • Fix sticky unread alerts could unexpectedly occur due to (effectively undocumented) 'auto read' functionality in XF2.2
  • Fix confusion over view_date vs read_date not being correctly used in the expected places
  • Fix alerts pop-up not respecting "Days to retain viewed alerts in popup" option in all cases
  • Fix 'mark read' functionality could result in inconsistent view/read date for older alerts near the expiry...
  • #8
2.9.2 - Bugfix update
  • Require Standard Library by Xon v1.18.0+
  • Fix alert summarizing only triggered on +25 unread alerts instead of the user-defined threshold
  • Fix summary alerts in the alert pop-up would be pushed under the just read alerts as if it had been read a while ago
  • Adjust "Alert summarize limit" option description text to better describe what a limit of 0 does (ie no limit)
    add onalert improvements by xon add ons alert improvements by xon add ons alert improvements by xon nulled add ons alert improvements by xon xenforo alert improvements by xon 2.10.1 alert improvements by xon 2.10.12 alert improvements by xon 2.10.13 alert improvements by xon 2.10.3 alert improvements by xon 2.10.6 alert improvements by xon 2.10.7 alert improvements by xon 2.10.8 alert improvements by xon 2.10.9 alert improvements by xon 2.11.1 alert improvements by xon 2.12.2 alert improvements by xon 2.13.0 alert improvements by xon 2.13.1 alert improvements by xon 2.8.22 alert improvements by xon 2.9.0 alert improvements by xon 2.9.1 alert improvements by xon 2.9.2 alert improvements by xon 2.9.4 alert improvements by xon 2.9.5 download add ons alert improvements by xon nulled add ons alert improvements by xon nulled alert improvements by xon xenforo add ons alert improvements by xon xenforo alert improvements by xon xnforo.ir انجمن های پشتیبانی زنفورو دانلود افزونه های زنفورو
