L Lovester Registered Aug 15, 2021 #51 Marks-Man said: I will need to check it tomorrow , maybe if we removed them the addon might stop working properly Click to expand... Hi, did you checked those callbacks??
Marks-Man Loyal Member Aug 15, 2021 #52 Lovester said: Hi, did you checked those callbacks?? Click to expand... I was waiting for @XenForo to update to 1.4.4 then I will fix it on new version. anyway will check it today
L Lovester Registered Aug 15, 2021 #53 Marks-Man said: I was waiting for @XenForo to update to 1.4.4 then I will fix it on new version. anyway will check it today Click to expand... yeah, alright.. thanks
Marks-Man Loyal Member Aug 15, 2021 #54 GOVERNOR said: Im using the latest update but i got this error AMPXFsrc/addons/MaZ/AMP/Cron/Version.php Unexpected contentssrc/addons/MaZ/AMP/Setup.php Unexpected contents Click to expand... @XenForo should have generated new file hashes after nulling the plugin, anyway this will not cause any problems, only errors show about file content
XenForo Administrative Aug 15, 2021 Thread starter Admin #55 Marks-Man said: @XenForo should have generated new file hashes after nulling the plugin, anyway this will not cause any problems, only errors show about file content Click to expand... Yes, new hashes will be loaded
