Is there a way that a custom field could be changed/an option chose on click?
So for example - if I had a title above a node that said 'Do you like the colour red?' and the options were Yes or No - Clicking on 'Yes' would record that option as a choice for that field.
The field wouldn't be visible, as I say - but would be represented as a link.
Thank you
Thank you
