XenForo Administrative Mar 28, 2021 Thread starter Admin #6 duppy said: I really don't see any place to set the permissions, unless I am missing something Click to expand... You check the plugin settings and user groups, in that section there are administrative permissions, check them
duppy XF-Fan Loyal Member Mar 28, 2021 #7 XenForo said: You check the plugin settings and user groups, in that section there are administrative permissions, check them Click to expand... I'll recheck it, but I am pretty sure there weren't any settings for that plugin.
duppy XF-Fan Loyal Member Mar 28, 2021 #8 I don't see any setting for it under User Group, and I also don't see any options for the plugin management. Sorry if I am missing it, but I am checking every possible screen for something related to the plugin.
XenForo Administrative Mar 28, 2021 Thread starter Admin #9 There is a flag for the "config.php" with which you can activate the renaming of a table/column. SQL: $config['X0815']['ChkTables']['renameData'] = true;
duppy XF-Fan Loyal Member Mar 28, 2021 #10 XenForo said: $config['X0815']['ChkTables']['renameData'] = true Click to expand... You're awesome! That worked great. Thank you very much, Duppy
