Discord Integration
Add-ons Discord Integration 2.8.7
[NixFifty] Discord Integration - Connect your Discord server to your XenForo board
Discord Integration allows you to establish a connection and manage your Discord server from the comfort of the XenForo Admin Control Panel. This is a free upgrade if you already own an active license to the original Discord Integration.
  • #3
XenForo updated [NixFifty] Discord Integration with a new update entry:
Version 2.5.2
  • Add support for announcement channels so notifications can be cross-posted to them.
Version 2.5.1
  • Strip extraneous characters from mirrored alert messages
Version 2.5.0
  • Require XenForo 2.2+.
  • Require PHP 7.2+.
  • Require Standard Library.
  • Confirm support for XF 2.2.0.
  • Harden various template modifications.
  • Remove user from server roles when they disassociate or get banned.
    add ons [nixfifty] discord integration discord integration 2.5.6 discord integration 2.5.7 discord integration 2.8.3 discord integration 2.8.7 download [nixfifty] discord integration download [nixfifty] discord integration 2.7.8 nulled add ons [nixfifty] discord integration nulled [nixfifty] discord integration xenforo add ons [nixfifty] discord integration xenforo [nixfifty] discord integration xnforo.ir [nixfifty] discord integration [nixfifty] discord integration 2.5.6 [nixfifty] discord integration 2.5.7 [nixfifty] discord integration 2.6.0 [nixfifty] discord integration 2.7.8 [nixfifty] discord integration 2.8.3 [nixfifty] discord integration xenforo انجمن های پشتیبانی زنفورو دانلود افزونه های زنفورو
