Dokan Pro
WP Plugins Dokan Pro 3.7.19
CodeCanyon
  • Moderator
CodeCanyon submitted a new resource:
Dokan Pro - Plugin Nulled Free Premium
Dokan PRO NULLED was built by WordPress users, for WordPress users so you can assured that you are in capable hands. This WordPress plugin brings entrepreneurship to your fingertips. Start creating your eCommerce brand with Dokan Multi-vendor Marketplace solution.
Dokan saves you hundreds of work hours while creating an online marketplace. See some of the many reasons that make it the #1 Open-source Multi Vendor Solution...
CodeCanyon
  • Moderator
CodeCanyon updated Dokan Pro with a new update entry:
Dokan Pro v3.7.19 NULLED Business
- **update:** [StripeExpress] Moved some CSS code to the Astra theme support folder.
- **fix:** Fixed a design issue under the Social profile link on the vendor dashboard.
- **fix:** [ProductReviews] Fixed bulk actions are not working on the review list page under vendor dashboard
- **fix:** Fixed some PHP warning under admin dashboard users profile edit page
