DarKMaSK Loyal Member Apr 23, 2021 #86 alodda said: i found an error check this In app.less add if not include in the end of file Less: {{ include('app_content_vote.less') }} Click to expand... In the child or in the parent?
DarKMaSK Loyal Member Apr 23, 2021 #87 Another problem is there. See the image: See the difference between the node marked in Red with the node above?
alodda Loyal Member Registered Apr 23, 2021 #88 DarKMaSK said: In the child or in the parent? Click to expand... on the parent & child
alodda Loyal Member Registered Apr 23, 2021 #89 DarKMaSK said: Another problem is there. See the image: See the difference between the node marked in Red with the node above? Click to expand... I did not have this problem? how many sub-forums do you use verify here perhaps ?
DarKMaSK Loyal Member Apr 23, 2021 #90 alodda said: I did not have this problem? how many sub-forums do you use Click to expand... 4 to 5 sub-forums. It can go upto 8 or more... it depends. But this number should not affect the design.
