Exclusive Dark
XF Style Exclusive Dark 2.2.15
duppy
XF-Fan
I want to set the icons myself, but I can't do it in the new theme.
I believe you can turn that option on/off in the style properties under the node settings. That's assuming you are trying to get the ultimate custom nodes plugin to function. I could be wrong, but I am sure I ran in to this issue as well.
I don't have any problem. All icons are working well, may be because of I have not used any third party plugin to change the node icons. Take a look here: My forum . In fact I am using the default node icons of the theme itself. 😬😇
Everyone is a learner, we always learn something new 😄 No one knows everything my friend. You are always welcome ☺️
Most of theme developers do merge templates manually, but keep in mind to track template errors and fix them just incase 😬
You were right. After manually merging the old templates, my Amazon Associate ad is not showing. What should I do?
    exclusive dark 2.2.12 exclusive dark 2.2.13 exclusive dark 2.2.15 exclusive dark 2.2.4 exclusive dark 2.2.6.1 exclusive dark 2.2.8
