Exclusive Dark
XF Style Exclusive Dark 2.2.15
Jakirul
HI, only problem i found with this older style on XF 2.2.4 if you use the vote-up or vote-down system this style seem to lose the threads. Not sure if you tested yourself? and found this problem. If you do not use the XF vote system it seem to work OK
i have
I am not using vote system as I am using '[XTR] Reputation System'. But still, I will report here, if I find any issue.
This may also be related to plugins, as I did not see any issues with the Localhost server
I have uploaded the test site to my server as testing purpose and still it is working smoothly. But I will upload the site again with these plugins and will see if any error occurs. I will update my findings here.
Marks-Man
You can try to disable plugins and uninstall them from control panel, rebuild caches, and recheck
    exclusive dark 2.2.12 exclusive dark 2.2.13 exclusive dark 2.2.15 exclusive dark 2.2.4 exclusive dark 2.2.6.1 exclusive dark 2.2.8
