IPS Suite Explain how to do Tips for removing + Create option
Haim
1) I want this button to be removed from the header
To do this, comment out the following lines in the userBar template. But you have to understand that the ability to create quick ads is also there....
<li id='cCreate'>
                <a href='#elCreateNew_menu' id='elCreateNew' data-ipsTooltip data-ipsMenu title='{lang="create_menu_title"}'>
                    <i class='fa fa-plus'></i> &nbsp;{lang="create_menu"} <i class='fa fa-caret-down'></i>
                </a>
                <div id='elCreateNew_menu' class='ipsMenu ipsMenu_auto ipsHide'>
                    <ul>
                        {{foreach \IPS\Member::loggedIn()->createMenu() as $k => $url}}
                            <li class="ipsMenu_item">
                                <a href="{$url['link']}"
                                {{if isset( $url['extraData'] )}}
                                    {{foreach $url['extraData'] as $data => $v}}
                                        {$data}="{$v}"
                                    {{endforeach}}
                                {{endif}}
                                {{if isset($url['title']) AND $url['title']}} data-ipsDialog-title='{lang="$url['title']"}'{{endif}}
                                {{if isset($url['flashMessage'])}} data-ipsdialog-flashmessage="{lang="$url['flashMessage']"}"{{endif}}
                                >{lang="$k"}</a>
                            </li>
                        {{endforeach}}
                    </ul>
                </div>
            </li>
2) the start new topic button should be deleted on the main page of the forum
forums > front > index > index comment out the following lines:
<div class='ipsPageHeader ipsClearfix ipsMargin_bottom cForumHeader ipsHeaderButtons ipsFlex ipsFlex-ai:center ipsFlex-jc:between'>
    <h1 class='ipsType_pageTitle ipsFlex-flex:11 ipsType_break'>
        {lang="forums"}
    </h1>
    {{if \IPS\forums\Forum::canOnAny( 'add' ) }}
        <ul class='ipsToolList ipsToolList_horizontal ipsClearfix sm:ipsPos_none sm:ipsMargin:none ipsFlex-flex:00'>
            <li class='ipsToolList_primaryAction ipsResponsive_hidePhone'>
                <a class="ipsButton ipsButton_medium ipsButton_important" href="{url="app=forums&module=forums&controller=forums&do=add" seoTemplate="topic_non_forum_add_button"}" data-ipsDialog data-ipsDialog-size='narrow' data-ipsDialog-title='{lang="select_forum"}'>{lang="start_new_topic"}</a>
            </li>
            {template="viewChange" group="global" app="forums" params=""}
        </ul>
    {{endif}}
</div>
