[RSS Feed/News] field-adder breaks if it contains tokeninput
You end up with:
Uncaught TypeError: Cannot read properties of undefined (reading 'replace')
It's because the hidden input fields that select2 use don't have names.
I didn't test it too much, but perhaps it would be more appropriate for the .find selectors inside XF.FieldAdder.create() to be .find('input[name*="{counter}"], select[name*="{counter}"], textarea[name*="{counter}"]') rather than .find('input, select, textarea')?
Or check if there is a name attribute before...
Read more about this Feed . . .
