XenForo Administrative Apr 2, 2021 Thread starter Admin #16 david said: There is a problem with this forum And there is no order in access I do not understand it is very difficult and complicated Click to expand... What is problematic and difficult?
XenForo Administrative Apr 2, 2021 Thread starter Admin #17 En1gma said: Not sure if this is what you mean... Some instructions on setup would be great by the addon's creator... Permissions for usergroups have been set up, not sure if anything else needs added or edited.. Click to expand... I did not work with this plugin, you probably have a problem with the online streaming link
david Registered Apr 2, 2021 #18 XenForo said: What is problematic and difficult? Click to expand... Thanks for the files and your prompt reply The process of using your forum was simple, but new problems arise every day
XenForo Administrative Apr 2, 2021 Thread starter Admin #19 david said: The process of using your forum was simple, but new problems arise every day Click to expand... What is your problem? Tell us to check
informer Registered Apr 2, 2021 #20 XenForo said: Доступ разрешен только для пользователей Click to expand... а я кто тогда? пользователь?
