I have added the SQL, so now should I disable the google ReCaptcha, the one am using before?I have created a resource that will help you, wait it is approved and you can do everything according to the instructions
Add-ons - CAPTCHA question-answer with examples
Hi, maybe this will be useful to many. There are only about 200 examples Plus and Minus, and more precisely 123 entries And there are also such 350 - 1 + 32 + 28 =answer in numbers. + 2 Tasks, but the answer is also in numbers. We go to our...xnforo.ir
