T thienlong09 Registered Jul 26, 2021 Thread starter #1 Please guide me how to add drop down button in navigation here is an example
Solution XenForo Aug 1, 2021 thienlong09 said: Please guide me how to add drop down button in navigation Click to expand... This is the default mode Check out more features with these plugins Add-ons - [OzzModz] Advanced Node List Widget - History xnforo.ir Add-ons - [XTR] Node List Widget - History xnforo.ir
T thienlong09 Registered Jul 26, 2021 Thread starter #3 XenForo said: Your image is not visible Click to expand... i use imgur i fixed it to add.pics did you see the image ? Upvote 1 Downvote
kutaz XF is cool thing Loyal Member Jul 30, 2021 #4 Can u tell more what do u mean? Upvote 1 Downvote
XenForo Administrative Aug 1, 2021 Admin #5 thienlong09 said: Please guide me how to add drop down button in navigation Click to expand... This is the default mode Check out more features with these plugins Add-ons - [OzzModz] Advanced Node List Widget - History xnforo.ir Add-ons - [XTR] Node List Widget - History xnforo.ir Upvote 0 Downvote Solution
