Support i need help in this error
Father121
An exception occurred: [Error] Call to undefined function XF\Mvc\Entity\gc_collect_cycles() in src/XF/Mvc/Entity/Manager.php on line 931
  1. XF\Mvc\Entity\Manager->clearEntityCache() in src/XF/AddOn/DataManager.php at line 130
  2. XF\AddOn\DataManager->rebuildActiveAddOnCache() in src/XF/App.php at line 1646
  3. XF\App->XF\{closure}() in src/XF/Install/App.php at line 116
  4. XF\Install\App->XF\Install\{closure}() in src/XF/Container.php at line 33
  5. XF\Container->offsetGet() in src/XF/App.php at line 2799
  6. XF\App->setupAddOnComposerAutoload() in src/XF/Install/App.php at line 199
  7. XF\Install\App->setup() in src/XF.php at line 779
  8. XF::setupApp() in src/XF.php at line 802
  9. XF::runApp() in install/index.php at line 16
fuitee
The error indicates that the gc_collect_cycles() function is undefined, likely due to garbage collection being disabled. To resolve this:
  1. Check PHP Version: Ensure you're using eggy car PHP 5.3 or later.
  2. Enable Garbage Collection: Add gc_enable(); in your php.ini file if it's not enabled.
  3. Restart Your Web Server: Restart Apache or Nginx after changes.
  4. Check Extensions: Ensure all necessary PHP extensions are enabled.
If issues persist, consult the application’s documentation or support community.
